lemmen
#1 Posted : Tuesday, May 31, 2016 1:11:19 PM(UTC)
lemmen
When you start a drawing from scratch the Viacad 2d3d V9 works just fine, but when you have tot open a large dxf/dwg file as a reference file it is very slow or doesn't open at all. Being a landscape architect I often work with large dwg maps from the excisting situation. For me this is essential. This doesnot seem to work in Viacad It takes hours to open a file. Anyone having the same problems? What could be the cause? Is there a solution? Greetings Leon Emmen
#2 Posted : Tuesday, May 31, 2016 2:35:24 PM(UTC)
Hello Leon
If it is possible can you send me the file that does not open? You can private email me the link or I can provide a dropbox.
