Hi Team!
Need some advice how to customize my ViaCAD Pro 9 User Interface to work better with multiple screens. Currently I'm working of a Mac book Pro and I have two 27" Apple Thunderbolt displays daisy chained together.
The issue I'm having the dynamic UI element at the top is stuck on my laptop screen and I would like to undock it and move it to my bigger screen.
Whats the best way to go about this?
Many Thanks!
Greg
Thanks: 38 times Was thanked: 64 time(s) in 46 post(s)
Hi Greg
Go into your MaBook, select System Preferences > Displays and click on the Arrangement tab.
You can then move the system MenuBar to the middle display.
If you right click, two finger press your ViaCAD icon in your dock, you get Options...then set the Display or Desktop to Display 1, 2 or 3 , and after a Restart ViaCAD should always open on that display when you are plugged into them.
Hope this helps
Mike
Edited by user Thursday, October 6, 2016 9:32:30 AM(UTC)
macOS Sequoia - MacBook M1 Max 64GB 2TB SSD & external display - SharkCAD Pro v14.1.0 build 1654 macOS Tahoe - v16 beta
Originally Posted by: 24c Hi Greg Go into your MaBook, select System Preferences > Displays and click on the Arrangement tab. You can then move the system MenuBar to the middle display. If you right click, two finger press your ViaCAD icon in your dock, you get Options...then set the Display or Desktop to Display 1, 2 or 3 , and after a Restart ViaCAD should always open on that display when you are plugged into them. Hope this helps Mike
Thanks Mike! That worked!
