I work with ViaCad 10 pro and in the past I could place an object or whatever above the grid (with the Z position).
Now always the grid is above my object, how comes?
Anyone kwows?
Thanks in advance
theo52 attached the following image(s):
(20kb) downloaded 14  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: theo52  Hi,
Hello
The grid locates on the origin of the workplane, so if your workplane is above the object that is where the grid will display.
Use the workplane --> set origin
                Thanks Jdi000
                Theo
                Hi Jason,
I can post a sample file, I can take all files, no matter which one, all the same problem.
I notice that if you open my file it will be opened in your ViaCad program and perhaps there is no problem at yours.
So I will attach 1 files and a few images the way it looks on my computer.
Thanks, Theo
 bold.vcp
(1,136kb) downloaded 13  time(s). theo52 attached the following image(s):
(6kb) downloaded 10  time(s). You cannot  view/download attachments. Try to login or register.
                Can you check that your View : Shade Options : Zuffer Curves is enabled?
(108kb) downloaded 8  time(s). You cannot  view/download attachments. Try to login or register.
                YESSSSS!
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
