Thanks, Tim
There are inconsistencies in the naming of other commands as well. I've attached a list I compiled as part of my project, It lists the shortcut names and actual command names. There is a multitude of minor differences, and some that are more major.
The first three columns of the sheet are Menu, Submenu and Command. Command indicates the name of the command as given in SFX shortcut list. Submenu is the menu/category given in the same. Menu is the location inferred from actual menus.
The fourth column—"Menus?"—is where I wrote whether there is a menu item that corresponds to the offered shortcut. Many only have icons, and some I could not identify.
Real Menu and Real Submenu columns show the real location of each corresponding menu item. Real Command gives its name as written in the regular menu, if the name differs from the name of the shortcut. Many do.
While most relationships are fairly clear, some were hard to infer and some I've not been at all able to correlate.
I've included the list in the hope it may be of use to you, should you want to increase consistency of the names, or to someone else like me who likes to play with shortcuts.
Edited by user Sunday, January 29, 2017 7:28:22 PM(UTC)
| Reason: Added a CSV file for anyone who wants to manipulate the data.
Shortcuts.pdf
(65kb) downloaded 34 time(s).
Shortcuts.csv.zip
(6kb) downloaded 10 time(s).
Shortcuts2.csv.zip
(9kb) downloaded 10 time(s).You cannot view/download attachments. Try to login or register.
