Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Hi @ all I want to try out the funktion of MateFace. Generally I have understood but there is an option window and I can't see any reaction of it. The option means an Offset but I have everytime the same result. Has anyone experiences with it? Regards Horst
Thanks: 195 times Was thanked: 163 time(s) in 112 post(s)
The Offset is the distance between the two faces you are mating. Like maybe the faces of two bearings, and leaving a distance for a spacer, or a shaft. I think the tools are mainly for assembly of multiple parts. Larry
i cannot see an option window, but you can use the option key to avoid associativity of the mated objects
Thanks for the answers!
@ Rokoko
I'm using Windows 7 Prof and the Option-Key (Mac?) is Control / Stgr but it has no effects.
Please have a look to the pictures, the starting situation and the result. With an given Offset of 30 mm I reach the same if I let it to zero.
That may be have a relation to a curios thing when I start the funktion.
Taging ON the MateFace-Symbol, also the symbol of his neighbor the Align-Function is taged ON. I can't set it to deactive without deactivation of the MateFace. Only tag ON the Align-Symbol is possible.
When using the function, with the first mouse-cklick to the first solid face, the Align-symbol is deselected.
Horst
PS: when a click to the MateFace-symbol, the mouse-flash becomes the symbol of the Align-function !
Edited by user Tuesday, January 31, 2017 2:29:13 PM(UTC)
(91kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
>>Taging ON the MateFace-Symbol, also the symbol of his neighbor the Align-Function is taged ON. FYI, this was recently corrected and will be in the next upload. Tim
