I've drawn a closed profile in 2D, and would like to perform lathe solid at the long axis. The result is unfortunately not what I expected.
See pictures.
(1,096kb) downloaded 26 time(s). LatheSolid.vcp
(31kb) downloaded 23 time(s). You cannot view/download attachments. Try to login or register.
ViaCAD 10 PRO + PowerPack / MAC OSX 10.12 Sierra
hi, you need an extra line as a lathe axis.
see file. i added line328
LatheSolid_01.vcp
(20kb) downloaded 20 time(s). You cannot view/download attachments. Try to login or register.
Thank you! I'm trying to make a pipe of it. It is said there is a gap? How do I find and close it?
Originally Posted by: ipc1-de Thank you! I'm trying to make a pipe of it. It is said there is a gap? How do I find and close it?
Hello
Rt click on one line of the profile and use chain select to see where the selection chain stops.
Hello
Your profile in the earlier post is a polyline all joined so there are no gaps in that.
Could it be possible that you selected the single line that you drew for the lathe line, when you selected the profile. If you make a lathe line that is offset from the profile and a different color you can make sure you are not accidentally selecting this with the profile.
(7kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
>>Could it be possible that you selected the single line that you drew for the lathe line, when you selected the profile. Thanks for the heads up Jason. The axis needs to be a 2 pt line, not a polyline. I added in a valid axis check in the next upload. Tim
I don't understand it, but
- there is no gap (select chaine)
- Lathe Solid is running with a construction lines I gave it to the endpoints of the left long line as an axis;
- Lathe Solid is also running by marking the model with a click in the right area of lines (all lines are marked red) and click the left long lines (which is also marked red) an other times as axis - but with a wrong result!
regards
horst.w, GER
Edited by user Wednesday, February 22, 2017 4:28:33 PM(UTC)
(33kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: horst.w I don't understand it, but - there is no gap (select chaine) - Lathe Solid is running with a construction lines I gave it to the endpoints of the left long line as an axis; - Lathe Solid is also running by marking the model with a click in the right area of lines (all lines are marked red) and click the left long lines (which is also marked red) an other times as axis - but with a wrong result! regards horst.w, GER
Hello Horst
The original profile is a polyline a buch of small lines joined as one. The lathe tool needs a non polyline line as the axis to get the correct results. If I change the profile to lines I get correct profile using the left long line without even drawing a new axis. Or I get correct profile if I draw a quick axis line and use that.
(45kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Aaaagggrrrrrr! Server Error in '/' Application. Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that <machineKey> configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Yes, thanks! It isn't a real problem for me but I like to understand always the coherences.
When I open the properties with the right mouse-key and there ChangeObjectType, than the first checkbox - lines - is taged on.
I figure that this is the actually state, and if not, how I can determine it. When changing the object type - change to polylines - no message comes up like ... "The object just is a polyline ..." or like such a message ... "Object to convert ... Converting will remove ..."
By trying that a have choosen Polyline and >>> OK. No message at all. When I try to reverse that by checking on Lines, the Converting-Messages are coming up.
Horst
Edited by user Thursday, February 23, 2017 1:52:25 AM(UTC)
I try using the "Shell Feature" the make a hole inside, to get a pipe. I can't find a gap?!?
Is there a 'Gap-Find-And-Close-Tool'?
(1,280kb) downloaded 10 time(s). LatheSolid_02.vcp
(67kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
What the hell are lumps?
See attached file.
(1,201kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
The shell tool offsets each face the given amount. You normally cannot shell a part with a value that is higher then the smallest feature in your part.
The hole tool removes a cylinder bore through the part.
(186kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
