NWIR
#1 Posted : Wednesday, April 5, 2017 12:48:19 PM(UTC)
NWIR
Wireframe cylinders in VCP10 display differently than VCP9. They don't display the full wireframe, just the circular ends. The same file in VCP9 displays the full wireframe.
Is this some change in the defaults?
NWIR attached the following image(s):
#2 Posted : Wednesday, April 5, 2017 2:10:08 PM(UTC)
Hello NWIR
In V10 the silhouettes need to be set to "on" vs smart in order for the solids to show the same as V9. Not sure why Tim would have to provide some insight
See thread
http://forum.punchcad.co....aspx?g=posts&t=8388
NWIR
#3 Posted : Wednesday, April 5, 2017 3:05:09 PM(UTC)
NWIR
Thanks for pointing to the previous post. That does seem to be the problem.
When I select "Smart" in display preferences, in Inspector, the selection goes "OFF". There is some interaction that isn't right.
-Jess
