#1 Posted : Sunday, April 9, 2017 8:51:15 AM(UTC)
Was thanked: 190 time(s) in 135 post(s)
Also when using some child-windows like Concept Explorer or select mask, the 3DConnexion will be disabled and only after click in the main window works it again. Thats not good, please fix it so that the 3DConnexion always works, also when inside a child-window. It will be also disabled when working with a tool and activating a field for typing a value while operation. Hoping it will be possible that the 3DConnexion item always works, also while the curser in a child-windows is active.
Edited by user Sunday, April 9, 2017 11:44:28 AM(UTC)  | Reason: Not specified
