Suggestions
Linear duplicate is extremely slow
Thanks: 323 times Was thanked: 197 time(s) in 138 post(s)
In draftboard it works 1000000 x faster.
Hello Are you trying complex geometry or simple objects ? Regards Jason
Simple objects but 100x100
This should now be fixed in 1338+ builds. There was a pre and post process command done for every copied item instead of once per command.
Same for the polar array, it also is significantly faster when using many objects.
Many thanks for the heads up.
Edited by user Monday, April 10, 2017 12:58:48 PM(UTC)
Suggestions
