Suggestions
Bending - Only bending the area between selected points and not the whole solid along the axis
Thanks: 304 times Was thanked: 180 time(s) in 127 post(s)
This is needed for bending a real planned developable surface of a simple box. At time is it needed to remove some parts of the developable surface before bending.
Edited by user Sunday, April 9, 2017 9:33:18 AM(UTC)
>> not the whole solid along the axis Is it possible you are using the Center Bend instead of Bend? Tim
No, i want that it bend not the whole solid along the bend-axis which you select with the 2 points. This is sometimes needed when creating real Models of a sheet-box.
I would probably need a specific example to see if ACIS can do it in your context. Attached is a bend between two points.
(112kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Very nice, maybe i made something wrong and didn't find out, that it with the bend-tool works. But after testing the bend-tool i decided to use the center-bend always because the construction of the bend-axis was easyer for me with the center bend, and with the center-bend it works not .
maybe i need more space and circles in the edges was not a good idea... :) When the space to small, it bends longer than the axis also with bend tool.
(42kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Can you post your example? Tim
Originally Posted by: Tim Olson Can you post your example? Tim
I will just make first a better developable surface, This one with the circles in the edges works not in both tools, its not needed to provide because it's wrong. It was my first. In this boxes are only one hole in the middle, therefore i was able to make this boxes with the extruding tool and the edges with adding other solids. Tomorrow i will provide a simple box.
Edited by user Wednesday, April 12, 2017 12:20:45 PM(UTC)
(42kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Very nice! Are you calculating the location depth of the bend points using a k-factor ?
Edited by user Wednesday, April 12, 2017 2:20:11 PM(UTC)
Originally Posted by: Tim Olson Very nice! Are you calculating the location depth of the bend points using a k-factor ? Tim
No, i don't use a k-factor. I am developing sheets just for the 3D-Model, not for making a real cut. The real cut and bending make another factory. They have sheet-software and making a real developable surface by software from the 3d model which i give them. For my 3D-Model i don't need a bending radius, i have to give them just 3d models with hard edges and the bending radius will be made by software automatically. Therefore is the tool for removing the radius (remove face) very good for me. But something about the k-factor. If i need a bending Raw length i just can make a neutral line.
BTW The bending tool is not easy to handle. It's not easy to definite the bending direction and the the bending-side.
keep the good work
Edited by user Monday, April 17, 2017 8:28:22 AM(UTC)
It works not when making a good edge for welding.
test it by yourself, i added a stp export.
My first idea - only to use the center bend was the best idea. the bending tool works really so like it want but not like i want.
But such boxes i creating now in full 3D and dont need the bending Tool anymore.
Edited by user Tuesday, May 16, 2017 9:24:09 AM(UTC)
Test.stp
(2,925kb) downloaded 6 time(s). MPSchmied attached the following image(s):
(258kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Suggestions
