#1 Posted : Wednesday, April 26, 2017 9:11:00 AM(UTC)
Was thanked: 197 time(s) in 138 post(s)
When using the concepts explorer or the select mask or inspector and want going back to the main window to work on the construction is always a mouse click needed for making the main window active. When mouse out of this windows should this windows be no longer active and also should then the 3dconnexion work again.
