Hi Larry, hi Jason,
thank you very much for your effort !
Larry, great, as far as i can see, you just rounded one corner a little and suddenly the addition worked.
But how does it look if you re-import your STEP-Data?
On my computer it looks like that:
Don't worry, that "ghost snake" I got fairly often (and even worse), when exporting my part to STEP and re-importing to my ViaCAD.
Jason, I found an older version of my data which the analyser told to be ok, but those two examples of multiple or bad faces you show, are already there in that old version.
So i start again on that version and try to update all the modifications using the analyser and save to new versions fequently.
Maybe that works. We will see.
Thank you very much !!
Christoph
Edited by user Monday, May 1, 2017 10:00:01 AM(UTC)
| Reason: pics didn't show, now attached
Pomi attached the following image(s):
(79kb) downloaded 11 time(s).
(125kb) downloaded 10 time(s).You cannot view/download attachments. Try to login or register.
