hi all
see attached screenshots - im using polylines in a sheet view
as you can see the curves have small dots, is there a way to control the dots so not to show ?
Andrew
Andrew Gray attached the following image(s):
(30kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 60 times Was thanked: 46 time(s) in 32 post(s)
Hi Andrew
Try this.
select all
Top menu
edit
untick show points or Ctl D
Edited by user Tuesday, May 16, 2017 5:54:38 AM(UTC)
| Reason: left out edit
Thanks but it didn't work Andrew
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
Please go first in the view frame with a mouse click and after it activated you can select the area.
