Art Smith
#1 Posted : Saturday, May 6, 2017 3:27:29 PM(UTC)
Art Smith
v10.0.0 Build 1335 is representing solids in a very curious manner; see attached image. is there something funny going on or was something reset with the download of the build and I haven't found it ??? I've been through the complete wireframe/true solid representation menu to no avail............
Art Smith
artesmith@earthlink.net
Edited by user Wednesday, May 17, 2017 7:54:08 AM(UTC)  | Reason: Not specified
v10 solid model representation question.jpg (33kb) downloaded 18 time(s).
Art Smith
#2 Posted : Tuesday, May 16, 2017 11:18:10 AM(UTC)
Art Smith
more data on my suspect solid problem
Art
v10 solid model representation question2.jpg (47kb) downloaded 10 time(s).
#3 Posted : Wednesday, May 17, 2017 10:47:57 AM(UTC)
Hi Art
Does the part check ok using Verify : Check Object? Also does it give a proper volume with Verify : Volume.
Art Smith
#4 Posted : Wednesday, May 17, 2017 12:25:46 PM(UTC)
Art Smith
Tim-
"check object" reports questionable; see attached image. verify attributes look "reasonable"; an opinion on "proper" would take some work as the shape is a NACA 0024 with a non-standard truncated trailing edge.....
the perimeter (ie: the shape to extrude) has been checked with the PowerPack "Show Gaps" tool and indicates good.
Art Smith
v10 solid model representation question3.jpg (53kb) downloaded 15 time(s).
Art Smith
#5 Posted : Monday, May 22, 2017 11:22:59 AM(UTC)
Art Smith
starting from scratch on a clean layer with clean profiles from AeroPack fixed whatever was ailing it. strange the profile checked out fine with current PowerPack verification tools.....
Art Smith
