#1 Posted : Saturday, July 1, 2017 2:19:25 PM(UTC)
Was thanked: 187 time(s) in 133 post(s)
When restarting the program the print setup will be resetted to the standard printer, this is on my main system the pdf creator. A good was will be, Shark CAD save the print setup to the file and not to the main setup. Otherwise i can change the standard-printer in windows, but most time i print with the PDF Creator and under Windows is the changing of standard printer a little bit annoying.
Edited by user Sunday, July 2, 2017 2:28:17 AM(UTC)  | Reason: Not specified
