#1 Posted : Sunday, July 2, 2017 2:30:42 AM(UTC)
Was thanked: 197 time(s) in 138 post(s)
When working on construction layer and Mirroring a object and press ctrl to copy the item, the layer of the item will be broken and just changed to construction layer. The same when just using copy and paste. And the same when using copy and paste of the whole geometry. Copy and paste should keep all attributes of the items.
#2 Posted : Sunday, July 2, 2017 2:43:07 AM(UTC)
Solution found: Edit> Paste Options> Preserve Layers
rokoko
#3 Posted : Sunday, July 2, 2017 4:28:18 AM(UTC)
rokoko
see in preferences:
Edited by user Sunday, July 2, 2017 4:30:51 AM(UTC)  | Reason: Not specified
MPSchmied on 7/2/2017(UTC)
