Art Smith
#1 Posted : Wednesday, August 9, 2017 3:33:20 PM(UTC)
Art Smith
is there a way to blend (with either standard Shark or Powerpack tool(s)) the overhanging geometry shown in the attached image? failing that, how would one go about imposing the tube profile on the perimeter of the hoop?
thanks
Art
artesmith@earthlink.net
blend question for rod end.jpg (29kb) downloaded 7 time(s).
#2 Posted : Wednesday, August 9, 2017 7:33:19 PM(UTC)
Hi Art
You could try...
1. Face /Face blend (hold shift key to select each face)
2. Edge blend with retain features enabled.
3. Fixed width blend
Tough looking blend!
Art Smith
#3 Posted : Wednesday, August 9, 2017 9:45:48 PM(UTC)
Art Smith
Tim-
thanks for the blend ideas. couldn't make any of them work. a one rail sweep solid perpendicular to the perimeter curve followed by a blend fillet did the trick............ not eloquent but got the job done!
Art
one rail sweep solid perpendicular to perimeter curve.jpg (32kb) downloaded 10 time(s).
thanks 1 user thanked Art Smith for this useful post.
Kevin Eidsmore on 8/18/2017(UTC)
#4 Posted : Friday, August 11, 2017 10:24:51 AM(UTC)
Was thanked: 202 time(s) in 140 post(s)
There is also a Problem with removing the Blending with the tool "Remove Face".
Edited by user Friday, August 11, 2017 10:31:40 AM(UTC)  | Reason: Not specified
#5 Posted : Friday, August 11, 2017 1:31:47 PM(UTC)
Try holding the shift key and selecting the adjacent face blends.
