#1 Posted : Monday, September 18, 2017 5:31:09 AM(UTC)
A negative and a positive value for row spacing have the same effect - only positive. But when the Column spacing negative, the row spacing is then also negative also when a positive number in the field.
Edited by user Monday, September 18, 2017 5:40:45 AM(UTC)  | Reason: Not specified
