Jalaluddin
#1 Posted : Friday, October 20, 2017 10:03:22 PM(UTC)
Jalaluddin
I have labelled vertices and edges of a triakis truncated tetrahedron, but there is a lot of visual clutter as the labels are not hidden.
Is there a way to make them hide?
Otherwise hiding text is on my wish list for SharkCAD PRO 10.
Thanks in advance.
Jalaluddin
Edited by user Friday, October 20, 2017 10:05:30 PM(UTC)  | Reason: Not specified
triakis_tt.sfx (246kb) downloaded 6 time(s).
L. Banasky
#2 Posted : Saturday, October 21, 2017 6:02:35 AM(UTC)
L. Banasky
Hi Jalaluddin,
Right Click, Hide All-Text + Dimensions.
Hide All -Text + Dimensions.jpg (78kb) downloaded 3 time(s).
#3 Posted : Monday, October 23, 2017 3:27:03 AM(UTC)
Was thanked: 197 time(s) in 138 post(s)
If you want that your numbers are hidden by your object and only the numbers in foreground visible you cant use the Option "Screen Horiz". For this you have to create a new Working Plane for every Number for text in 3D Space. That the Screen Horiz. Text should be hidden by the Solid is maybe a good idea and is now also in my wishlist.
