has anyone else noticed anything strange with "hatching" in SharkCAD Pro (1363)?? I can't tell if there's something going on or hatching is just being its weird unpredictable self............. see attached image
Art
artesmith@earthlink.net Art Smith attached the following image(s):
(59kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hello Art Did you try hatching without grouping? Regards Jason
Jason-
hatching was attempted with and without "grouping"...... when it works, "hatching" is a great tool! conversely when it doesn't, "hatching" in my view is a great deal worse than a bad tool because it provides
NO insight into why! elementary descriptive geometry suggests sectioning a solid with a plane yields a planar closed perimeter........ ie: the region "hatching" says it didn't find.
Art
it occurred to me that the bulk of the file is not required for fault isolation so included below is a file with the layer in question
Art
artesmith@earthlink.net File Attachment(s):
hatching again 01-26-2018.sfx
(258kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Art
I added 2 lines (red) and hatched each section as a way to get this hatched.
(24kb) downloaded 3 time(s). You cannot view/download attachments. Try to login or register.
Jason-
thanks for the work around; it gets me moving forward again!! hopefully "hatching" makes someone's list for needed and worthy product improvements............
Art
Thanks: 230 times Was thanked: 182 time(s) in 110 post(s)
Originally Posted by: jdi000 Art I added 2 lines (red) and hatched each section as a way to get this hatched. Jason
Thanks Jason for the workaround.
I get the same Hatch problem as Art is mentioning very often...
