Using SharkCad Pro 10 on a MacBook Pro running macOS Sierra 10.12.6. Most of my work is with 3D Solid Modelling BUT recently I needed to draw up production drawings for a product & needed to place tolerances on the dimensions. I cannot find any way to get the tolerances to be displayed. This is something that really should work so how do you get them to display?? How would you turn them on or off??
Thanks: 351 times Was thanked: 255 time(s) in 168 post(s)
You can add text to the dimension. Select a dimension, open the inspector> Object Properties> Data and write "# +4" (example) in the text field. The # stand for the value and what you write after the # will printed after the value.
(12kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
The tolerances are a little further along those tabs in the image, the one that shows dimensions around a circle is what you want.
Hi ... I appreciates you input BUT look at the tolerance examples from the manual for this program, see attached. Sure some of the option could be solved with a simple change to the format ... placing a "±" followed by your tolerance value would be ok if the upper & lower tolerance values were the same. Many of the drawing require different values +0.00-0.25 ... these values are normally put vertically as shown in the attached photo taken from the manual. There is a location in the inspector window where you can input these tolerance values for a particular dimension BUT they seem to be for nothing.
In the manual in the section on the standard manager, they actually show 7 options for displaying the tolerances.
[img=/Users/leonprucha/Desktop/sfx User Guide.pdf]Tolarence discussed in manual ...[/img]
Has this been abandoned from the program??
leonp attached the following image(s):
(294kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Leon The tolerance work as expected by adding them in the dimension tab. Make sure you have the dimension selected when you make the change. Regards Jason
Did'nt find out that first time the Value Format have to be changed to a Format within Tolerances. If this made, the Upper Tol and Under Tol in the tolerance tab have a effect.
Edited by user Thursday, February 15, 2018 4:33:26 AM(UTC)
(21kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Leon
Were you able to access the tolerances as you needed?
Inspector
Dimension Properties Tab
Value Tab
Change the Value dropdown
Edited by user Saturday, February 17, 2018 9:57:18 AM(UTC)
(31kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
Hello Everyone that has replied to my post, particularly jdi000 & MPSchmied. Thank you for your help ... you have shown me where I needed to look to set the dimension format so that it included the tolerance values. Thank you.
Edited by user Tuesday, February 20, 2018 9:47:18 PM(UTC)
