NeuTechFLA
#1 Posted : Thursday, March 15, 2018 6:48:24 PM(UTC)
NeuTechFLA
Each time I have used MTS, my brain was doing flip-flops trying to reconcile what was being presented on the drawing relative to the model. So, I used a modeling technique (the cube) that I have used to demonstrate Sketch planes in CREO to help me understand what was occurring. This is when the issue with MTS became clear.
The default "front" model views between aerospace and default are different. But MTS does not seem to follow the model's "views definition" between default and aerospace. It's a bit confusing, but regardless of the setting "default" or "aerospace", MTS uses "default" as the view layout. This is not a good thing. Is this the issue many of you have been complaining for years?
UPDATE:
My apologies my friends, I forgot to attach the other pieces to the puzzle. Essentially MTS is "projecting" views properly but the views it is projecting are not correct views from the model. In other words, it would seem the canned, saved views in the model are not congruent with MTS.
Edited by user Friday, March 16, 2018 6:13:30 AM(UTC)  | Reason: Not specified
Jolyon
#2 Posted : Friday, March 16, 2018 2:24:02 AM(UTC)
Jolyon
Golly - yes, this affects me
I need to test this
NeuTechFLA
#3 Posted : Saturday, March 17, 2018 1:29:37 PM(UTC)
NeuTechFLA
Do we have the power to change the standard views within VC/Shark?
#4 Posted : Saturday, March 17, 2018 3:43:13 PM(UTC)
Create first a 3 pts plane and then view the plane and create a new view. This new view can be used in a draw view as a view option.
Edited by user Saturday, March 17, 2018 3:44:11 PM(UTC)  | Reason: Not specified
NeuTechFLA
#5 Posted : Saturday, March 17, 2018 5:41:09 PM(UTC)
NeuTechFLA
Thank you for the info. I have created a "Start Part" that has new model views that allow MTS to work properly with 3rd angle projection.
#6 Posted : Monday, March 19, 2018 8:44:45 AM(UTC)
This is very interesting, please tell me how you doing that.
#7 Posted : Monday, March 19, 2018 10:23:13 PM(UTC)
MTS uses template files. A template is a regular viacad file that contains a drawing border, title block, and any number of draw views.
The draw views in a template have "hard wired" view orientations that are independent of your views in ViaCAD.
You may want to consider creating a custom template with the view orientations you desire. I've attached a tip that shows how to create a custom template.
Edited by user Monday, March 19, 2018 10:25:12 PM(UTC)  | Reason: Not specified
CustomMTS.pdf (113kb) downloaded 21 time(s).
MPSchmied on 3/20/2018(UTC)
NeuTechFLA
#8 Posted : Tuesday, March 20, 2018 11:37:19 AM(UTC)
NeuTechFLA
Tim, it's not MTS that has the issue. MTS does in fact project views properly relative to the "TOP" view. The issue is in the model views specifically. The programmed "TOP" view and "FRONT" views are not orthographically correct relative to one another. You have them 90 degrees off in two axes. If memory serves, around the X and Z.
NeuTechFLA
#9 Posted : Tuesday, March 20, 2018 12:23:42 PM(UTC)
NeuTechFLA
This requires a few things to work.
1. Open a new part and set the view to TOP
2. Click "New View", name the View to whatever you want. I named mine; True Front.
a. Enter the appropriate X axis angle (I assume you use 1st angle projection)
b. Create New View, for the remaining five views all while keeping your projections correct.
c. Save the part with a name you will remember to use each time you start VC/Shark. Mine is named; Shark Aero Start.sfx
This is only for working in the model.
The following is my experience in Shark. I am not sure if ViaCad is the same. But...
3. When you are ready to create your drawing, use MTS and allow the software to place the views. Then, before adding dimensions, delete the two projected views derived from the TOP view. Then project the views you need for your drawing. You will need to use Update Views to get the correct features in each view.
What I do not know is if your projections will be 3rd angle or 1st angle. I think that was set up when your software was first configured.
If you have any issues, let me know and I will try to assist.
Edited by user Tuesday, March 20, 2018 12:31:49 PM(UTC)  | Reason: Not specified
thanks 1 user thanked NeuTechFLA for this useful post.
MPSchmied on 3/21/2018(UTC)
