#1 Posted : Tuesday, March 20, 2018 8:58:10 AM(UTC)
Afternoon,
I'm playing around with rendering in Shark, after my upgrade from VC, and noticed that if you select something like, wood or marble or whatever the render stays on, which I think is pretty smart. When I pick a metal, the render doesn't stay on, and in the render box of inspector there is no pull down tab available. Is this because the metal affect uses more graphics or something, or can this be adjusted?
Cheers
render on.jpg (300kb) downloaded 1 time(s).
render off.jpg (280kb) downloaded 5 time(s).
