Suggestions
screw - a little french-touch story (#3001)
If you want thread (fillet) on your bolt go to :
http://www.mcmaster.com/# METEORE DESIGN / KEKO Stand Jean-Francois Jacques, Industrial Designer SharkCad Pro V14 B1653 Platform macOS 14 Sonoma
Originally Posted by: la mouche Antoine
Where did you get your library of parts screw washer nut?
it is a work of the French. vive la France!!! :)
Regarding your parametric question at the end of you movie. This can be done with constraints and the variable/equations dialogue. I've been playing around with the constraints and setting forth dimensions relative to other dimensions. There's isn't much documentation on this and I've been playing around with it. This is an avenue to tackle setting forth different sizes on the go.
Suggestions
