Can't Copy Angle (Verify)
Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
I'm unable to use COPY to copy-paste an Angle from the Verify Angle 3pts. User error perhaps? :)
Can't click inside the field..
See attached...
Edited by user Tuesday, April 17, 2018 11:36:31 AM(UTC)
(59kb) downloaded 14 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
You can use double click at the field and then when selected press ctrl+c for copy. This works in Build 1369. For A2 works this not, but you can draft with the mouse over the amount and copy this value also.
Originally Posted by: MPSchmied You can use double click at the field and then when selected press ctrl+c for copy. This works in Build 1369. For A2 works this not, but you can draft with the mouse over the amount and copy this value also.
Thanks, but I unfortunately did already try these to no avail. Maybe my build is too old? I'm using 1359. I seem to always have trouble finding where to download new builds. When I go to Help > Current Version, all it says is that I'm running the latest build.
*To explain a bit further, when I click with the mouse into either A1 or A2 field, nothing happens. It is not recognized as something I can click inside. Also I tried to use the CMD-C (mac) to copy, and again nothing.
Edited by user Wednesday, April 18, 2018 4:11:54 PM(UTC)
| Reason: added more explanation
(65kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
I don't know whether this have to do something with the build number or with Macintosh. But you get downloadlinks of Work in Progress Builds here:
http://www.punchcadlabs.com/page7/page7.php OS: Windows 10 | CPU: AMD Ryzen 7 2700 | RAM: 32 GB | Graphic: AMD Radeon RX 7900 XT | SharkCAD 15 Pro | Unit: mm
I did some testing, and this seems to be a MAC issue. The PC versions all seem to allow you to click in the fields and copy. I will work with Tim to address this.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
Originally Posted by: Todd Quinlan I did some testing, and this seems to be a MAC issue. The PC versions all seem to allow you to click in the fields and copy. I will work with Tim to address this.
Understood. Thanks a bunch Todd!
Updated in 1370. Mac & PC now behave the same regarding copying these fields. Tim
