Mirror with infinite plane bug
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
When using Mirror with infinite Plane and change Tool and go later back to the mirror tool, it start with the wrong question "Select objects to mirror" instead of the right question: "Pick infinite plane to mirror about".
Windows 10 Version 1803 (Build 17134.5)
Edited by user Wednesday, May 2, 2018 2:04:32 AM(UTC)
(7kb) downloaded 1 time(s). You cannot view/download attachments. Try to login or register.
cannot repeat this on mac (viacad pro build 1359)
Yesterday i got the error very often. It happens when you use the Mirror over infinite Plane and then going to create a new infinite Plane. When going back to the Mirror tool, it will just start with the wrong question. I upgraded windows yesterday to the Version 1803 (Build 17134.5)(A Din A4 Page with settings have to be made after this procedure.....), but this have no effect for this bug.
(7kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
I was to get this repeat. This is now fixed in 1370 codestream. Tim
