Tom Kirsch
#1 Posted : Monday, May 7, 2018 11:29:11 AM(UTC)
Tom Kirsch
I am unable to print line weights. The all appear the same weight after printing although they range from .005 to .050. Is this a bug in V10.0 for Mac or a function of the scale ratio used for printing? Scale ratio = 0.05745; Single page 10.75/8.25; Engineering/ User Defined
MacOS 10.13.4 High Sierra, 32 GB Ram, Model 18-3 iMac
HDTV arrangement (front view) Rev.pdf (92kb) downloaded 2 time(s).
Tom Kirsch attached the following image(s):
Screen Shot 2018-05-07 at 9.38.43 AM.png (202kb) downloaded 1 time(s).
#2 Posted : Monday, May 7, 2018 11:44:12 AM(UTC)
Hello Tom
The line weights are scaled .05 like all other objects in your printed output.
Tom Kirsch on 5/7/2018(UTC)
#3 Posted : Monday, May 7, 2018 12:32:50 PM(UTC)
Was thanked: 255 time(s) in 168 post(s)
If you want the right size of dimensions, arrows and line weights and Text, you have to setup the Page Layout Scale to 1 und then you should using Draw Views and setup your needed Scale just in the Draw Views. The Draw views calculate the right Print Size of Line Weights, Arrows and Text. The Page Layout Scale do this not. The Page Layout Scale should be removed completely at all. Also the Model to sheet do setup the Page Layout wrong. Always if Using Model to Sheet is it needed to setup the page Layout Scale back to 1.
Edited by user Tuesday, May 8, 2018 2:10:28 AM(UTC)  | Reason: Not specified
