#1 Posted : Sunday, May 13, 2018 12:20:53 PM(UTC)
When you use Model to Sheet, your Page layout Scale will be destroyed to a unusable value. I have found out why.
This Page Layout Scale is saved in the Templates which are used for the Layout of the Drawing. Start SharkCAD or ViaCad as Administrator, open the Templates C:\Program Files\Punch! Software\SharkCAD 10\Templates\ModelToSheet\ (If using Via Cad or Shark CAD Pro the Path is wrong, replace "SharkCAD 10" with your Productname) and change the Page Layout Scale to 1 and save the files. If you use Model to sheet after changing the Templates, the Page Layout Scale stay at 1 and are no longer changed to unusable values.
And you can change the draw views for the european Multiview projection.
@ Posh.de. Nice german User Guide and translation in SharkCAD 9, but you forget the templates for Model to sheet. This are in all versions the same files from 2013. But i know it is a unthankful Job. Maybe this can be a user contributed Content.
Edited by user Thursday, May 17, 2018 5:17:25 AM(UTC)  | Reason: Not specified
