Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
I am running VC V10 on a mac laptop and PC. I'd like to transfer the settings/pref/shortcuts I have on the laptop to the PC. How would I do this?
Thanks: 347 times Was thanked: 247 time(s) in 164 post(s)
Save Settings from the old computer: Go to the Folder: "C:\Users\<youroldpcusername>\AppData\Local\Punch!\" and save the content completely at a USB stick.
Install the Software at your new computer and make some settings to be sure that the configs created.
Close ViaCad.
Copy the "...AppData\Local\Punch!\" Folder Content completely from the USB Stick to "C:\Users\<yournewpcusername>\AppData\Local\Punch!\
More easy go this with a syncronization software like Beyond Compare, or you pack the Content into a Zip or 7Zip Folder.
Edited by user Thursday, May 17, 2018 5:38:55 AM(UTC)
Originally Posted by: MPSchmied Save Settings from the old computer: Go to the Folder: "C:\Users\<youroldpcusername>\AppData\Local\Punch!\" and save the content completely at a USB stick. Install the Software at your new computer and make some settings to be sure that the configs created. Close ViaCad. Copy the "...AppData\Local\Punch!\" Folder Content completely from the USB Stick to "C:\Users\<yournewpcusername>\AppData\Local\Punch!\ More easy go this with a syncronization software like Beyond Compare, or you pack the Content into a Zip or 7Zip Folder.
What about moving the data from one mac to the other?
