#1 Posted : Friday, June 1, 2018 3:37:38 AM(UTC)
Morning all,
Looking at a way once a detail view is created, it seems to put the letter at the bottom of the circle at all times, how on earth do you move it? I'm finding it's not the most convenient place to have it....
Cheers
L. Banasky
#2 Posted : Friday, June 1, 2018 5:22:34 AM(UTC)
L. Banasky
Good morning,
Right click in the view- Properties- uncheck Draw name box, use Text to put in
new name, and you can place anywhere.
#3 Posted : Friday, June 1, 2018 6:24:21 AM(UTC)
Hi Larry,
Does this work with the letter it puts under the circle which you draw around the bit you want to make bigger?
Cheers
L. Banasky
#4 Posted : Friday, June 1, 2018 7:46:17 AM(UTC)
L. Banasky
Should work, use Deep Select.
