Import/Export
Do not install the new 1359 version if you use step files !
Thanks: 17 times Was thanked: 3 time(s) in 2 post(s)
For some reason the new 1359 Viacad pro version has problems importing step files. Small step files can still be imported but a bit larger ones not. After selecting the file during the import the program sometimes doesn't do anything or it will generate an error or the program just stops completely. Hopefully the development team can fix this quickly.
This bug has already been found and fixed. Keep an eye out for the next update by checking Current Version under the help menu.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
Originally Posted by: Todd Quinlan This bug has already been found and fixed. Keep an eye out for the next update by checking Current Version under the help menu.
That's great news. Hopefully we can see a new release with the fix soon.
Found and Fixed? I am still having problems. I have not been able to get step files imported for quite awhile. Last time I checked I could not import step files I created myself. Please tell me this is a problem with my individual setup. Art 10.0.6 1369 Mac 10.13.6
Art This was fixed and has broke again. Thanks Jason
Thanks Jason,
That is both reassuring and concerning at the same time.
Art
Edited by user Thursday, November 29, 2018 11:27:44 AM(UTC)
Art It is ok on windows, so maybe its something with mac and is not totally addressed. Regards Jason
Thanks: 211 times Was thanked: 150 time(s) in 95 post(s)
Originally Posted by: Art Found and Fixed? I am still having problems. I have not been able to get step files imported for quite awhile. Last time I checked I could not import step files I created myself. Art Mac 10.13.6
I'm still having problems too.
Please note :
drag-and-drop the step file into the window is working better than
File Menu-Import , sometimes...
Other point :
sometimes importing one part file works and importing a second one afterward crashes.
JL
This morning I'm having problems now with STP imports, and IGES for that matter.Last successful STP import was two weeks ago.
Brian Graham Mac OS Ventura 13.6.3 Mac mini Apple M1 16GB 1TB SSD Shark FXv 14 Build 1641
All
Please contact Todd at support if you need to use step files and are having an issue with Mac version. Windows had worked ok in my testing.
[email protected] Thanks
Import/Export
