Tips and Tutorials
How rendering photo realistic transparent glass?
Thanks: 361 times Was thanked: 268 time(s) in 175 post(s)
I created a glass and want make a high res image, but the glass is no more transparent after rendering with the photo render palette.
The GlassModel example file has some example settings for transparent glass. Tim
I opened this glassmodel example which i found in program files folder, and this transparency made i already by myself, after high res rendering is it no longer transparent, please watch it on the attached image.
(20kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Tips and Tutorials
