flatpack
#1 Posted : Friday, October 26, 2018 8:00:47 PM(UTC)
flatpack
Was thanked: 11 time(s) in 9 post(s)
Does anyone know how to duplicate an object (many multiples - using a linear array type operation) along a surface?
Its a curved surface and needs to follow a specific path with an equal distance between each object.
I'm using SharkCAD.
I attached a screenshot of what I need help with and also the .slt file.
Thanks in advance.
Rivets.slt (11kb) downloaded 1 time(s).
Rivets on surface.png (79kb) downloaded 0 time(s).
#2 Posted : Friday, October 26, 2018 11:38:22 PM(UTC)
Was thanked: 105 time(s) in 81 post(s)
Does 'path duplicate' pick up the curve on the surface? Not sure if it only works with straight lines or not.
**Edit**It does work, just tried it. Go MODIFY - ADVANCED TRANSFORM - PATH DUPLICATE. The last action '2 points for alignment axis, is basically start and end of the line you are going down.**
Edited by user Friday, October 26, 2018 11:51:36 PM(UTC)  | Reason: Not specified
Untitled 1.jpg (23kb) downloaded 0 time(s).
Shark CAD + Power Pack Pro
flatpack on 10/27/2018(UTC)
rockyroad_us
#3 Posted : Saturday, October 27, 2018 10:31:12 AM(UTC)
rockyroad_us
Was thanked: 24 time(s) in 23 post(s)
Just use the linear duplicate command since the surface is pretty much extruded straight. See example using -1" spacing with 20 duplicates.
FX 9-1224 Pro10-1371
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
flatpack
#4 Posted : Saturday, October 27, 2018 10:58:47 AM(UTC)
flatpack
THank you, I will try that also; what I'm trying to duplicate is a tiny rivet head along the Z axis (well along the curve in a general "Z-ish" direction).
flatpack
#5 Posted : Saturday, October 27, 2018 11:08:44 AM(UTC)
flatpack
I tried Path Duplicate and it works except I can't get the Rivet head to follow the contour. I'm not sure how to make it look like the rivets are actually installed in the curved surface. Its just for a rendering so doesn't need to be perfect.
The only other way I can think of is use Points on a Curve to make even-distance points and then manually place and rotate each.. But i can't help thinking there's an easier way.
Screen Shot 2018-10-27 at 1.09.17 PM.png (70kb) downloaded 3 time(s).
rockyroad_us
#6 Posted : Saturday, October 27, 2018 11:42:29 AM(UTC)
rockyroad_us
you need to use the pattern command with along path. This is in the 3D tools.
I take that back. that only works for a hole or a feature on the part that you want to duplicate. You are in the right track with path duplicate using the option tool to use the normal of the curve. It is best you place the rivet on the xy plane and follow the prompts. It is a bit tricky. Just don't put the first rivet on the curve but rather the xy plane.
Edited by user Saturday, October 27, 2018 11:57:36 AM(UTC)  | Reason: attaching pic
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
thanks 1 user thanked rockyroad_us for this useful post.
#7 Posted : Saturday, October 27, 2018 11:58:22 AM(UTC)
Suppose you can always use a sphere send the sphere down the curve, with path duplicate, so it's got a little sticking above the surface. Then use your surface to split the sphere solids, leaving you with a rivet head.
flatpack
#8 Posted : Saturday, October 27, 2018 12:15:48 PM(UTC)
flatpack
Hey! You did it! Thanks! Exactly what I was looking for. :)
flatpack
#9 Posted : Saturday, October 27, 2018 12:20:46 PM(UTC)
flatpack
8
Thank you! That's a really interesting AND workable solution. In the future it would be nice if there was a 3D Array tool that could be used for a variety of rather complex patterns. It could duplicate an object in all directions in a preset or numerically-driven manual input. Maybe its in the works -- or already exists and I just dont use it?
#10 Posted : Saturday, October 27, 2018 12:34:17 PM(UTC)
I've noticed with some of the pattern tools etc that the work plane affects the end result. So when you look at the work plane, you have the two big arrow outlines and the thin little arrow is what seems to be used in some instances.
flatpack
#11 Posted : Saturday, October 27, 2018 1:11:47 PM(UTC)
flatpack
Good point -– it takes some experimenting. I was able to get it this time but it was by adjusting where I was clicking on my object as its reference point, and also trying various "start" and "end" points. Each yielded a rather different result..
Antoine
#12 Posted : Monday, October 29, 2018 3:58:53 AM(UTC)
Antoine
Switzerland
Was thanked: 31 time(s) in 25 post(s)
Hello,
Maybe it will help you.
be careful, do not forget the hidden function ..... lol ?
option (Alt) when last entered with the mouse to choose the support surface.
https://www.dropbox.com/...licate%20normal.mp4?dl=0
Antoine
mrconcepts.ch
design-r.ch
SharkFX 10
MacOS 10.13.6
Mac Pro 2,7 GHz 12-Core Intel Xeon E5
AMD FirePro 6144 Mo
flatpack
#13 Posted : Monday, October 29, 2018 7:45:09 AM(UTC)
flatpack
I didn't know this! Thank you Antoine. And thanks for the video reference!
Antoine
#14 Posted : Monday, November 05, 2018 12:52:00 AM(UTC)
Antoine
Switzerland
Thank you.
Yes there are many things hidden in this software.
Unfortunately, the hidden options disappear from the menus with the years.
As I have already said often, the manual instructions must be corrected and above all, be made more attractive.
Antoine
mrconcepts.ch
design-r.ch
SharkFX 10
MacOS 10.13.6
AMD FirePro 6144 Mo
