#1 Posted : Saturday, December 29, 2018 3:44:30 PM(UTC)
Was thanked: 114 time(s) in 90 post(s)
I have a little mesh, which has 363 faces. Subdivide it once, and it'll allow me to right click and change object type to faces. Do it twice and it won't. Only once subdivided twice, the mesh analysis tells me it's still 363 faces. So which is wrong, the analysis, or the right click change object type?
Edited by user Saturday, December 29, 2018 3:58:02 PM(UTC)  | Reason: Not specified
ViaCAD Pro 10, 11 + Power Pack Pro
Shark CAD V12 + Power Pack Pro
Windows 10 Pro- MSI GL72 6QC-32GB RAM
murray
#2 Posted : Sunday, December 30, 2018 8:03:40 PM(UTC)
murray
Was thanked: 76 time(s) in 61 post(s)
Works for me. The facet count ramps up with subdivision applied as expected and the option to convert is available until the facet count exceeds 3K. That's the reason PowerPack Pro has convert to nurbs. PC here, Win 10. TurboCAD Pro and even FreeCAD can convert facet objects or meshes with much higher counts to solids or solid meshes, if you've a particular use for it.
Edited by user Sunday, December 30, 2018 8:14:15 PM(UTC)  | Reason: Not specified
#3 Posted : Monday, December 31, 2018 2:13:21 AM(UTC)
Hi Murray,
Sorry this is version 11, so in power pack Pro you don't have mesh to nurb anymore, it's gone in version 11. I'll try and do a video today and post it.
Cheers
#4 Posted : Monday, December 31, 2018 6:23:27 PM(UTC)
I tried this in both Shark and V11 and neither count went up, although it did allow me to change things to faces on a different mesh.
So if you draw a basic mesh shape and then sub divide the facet count changes?
murray
#5 Posted : Monday, December 31, 2018 7:14:53 PM(UTC)
murray
Yes. If you create a cube and repeatedly subdivide, it becomes a progressively closer approximation to a sphere, as if you were repeatedly chamfering all of its edges, which logically creates additional faces.
#6 Posted : Tuesday, January 01, 2019 11:54:46 PM(UTC)
So is this something else which isn't working right?
Edited by user Tuesday, January 01, 2019 11:56:36 PM(UTC)  | Reason: Not specified
ScreenCapture_2019-1-2 06.09.01.mp4 (3,066kb) downloaded 12 time(s).
murray
#7 Posted : Wednesday, January 02, 2019 5:50:14 AM(UTC)
murray
Seems that it isn't working right from the subdivide button. Apply a subD level in the inspector and it works as it should.
