PianoTondo
#1 Posted : Friday, January 25, 2019 4:31:04 AM(UTC)
PianoTondo
Hello Everyone,
I'm new with ViaCAD and CAD in general, I already worked in 3d for years but without this way of thinking.
Currently I'm working with the 2D design and interface in order to understand it.
I tried to use the function "OFFSET TO VALUE": I have a joined and closed curve composition and I want to create a offset of 2mm
So I take the "Offset to Value" command and I create a larger version of my track. The problem is that every corner become rounded.
I'd like to have them not rounded but normal.
Is there a way to achieve this?
Thanks, and have a nice day!
F
#2 Posted : Friday, January 25, 2019 5:37:05 AM(UTC)
Was thanked: 303 time(s) in 205 post(s)
I'd try it with open curves. Don't close them first. It can do some weird things if they are closed curves.
#3 Posted : Friday, January 25, 2019 7:28:31 AM(UTC)
This is no problem, if you want edges press just Ctrl at the same time when you click for the offset direction. It works also when you press Ctrl before u select curves and release ctrl after click for direction. But if you want selecting multiple curves fith the Shift-Key, you should press CTRL only when select offset direction location. Watch the Tool hints in the big Prompt, and Data Entry Window.
Edited by user Friday, January 25, 2019 7:40:39 AM(UTC)  | Reason: Not specified
PianoTondo
#4 Posted : Friday, January 25, 2019 10:19:35 AM(UTC)
PianoTondo
Hi!
Thanks for your precious help.
I'm outdoor now. Tomorrow I'll try both of your advices and I'll make you know :D
Thanks again, see ya!
F
PianoTondo
#5 Posted : Monday, January 28, 2019 3:21:26 AM(UTC)
PianoTondo
Ok, I tried. :D
It worked using CTRL and open curves. I can't make it work with a jointed curves form. Is it correct ?
But is there a way to decide the corner radius ? It's pretty strange that it's everything automatic.
horst.w
#6 Posted : Monday, January 28, 2019 12:38:05 PM(UTC)
horst.w
Reproducing what about here is spoken, I found
OFFSET Faces Edges
but I couldn't find out what this function is doing and how it is working.
Its new (for me) in the sub-menue of Trim... Join ...
HELP doesn't help!
horst.w
GER
Edited by user Monday, January 28, 2019 12:40:07 PM(UTC)  | Reason: Not specified
Offset Face.png (106kb) downloaded 0 time(s).
L. Banasky
#7 Posted : Monday, January 28, 2019 2:28:03 PM(UTC)
L. Banasky
Was thanked: 141 time(s) in 100 post(s)
It saves drawing a line to offset from. If you wanted to put a hole
a certain distance on a rounded surface you could mark the spot.
Or cut out a section, might be useful.
Offset Face Edges.jpg (76kb) downloaded 4 time(s).
horst.w
#8 Posted : Monday, January 28, 2019 2:38:54 PM(UTC)
horst.w
Many thanks for clarification!
Horst
Very useful function for me!!!
Edited by user Monday, January 28, 2019 3:24:52 PM(UTC)  | Reason: Not specified
Offset Face.png (59kb) downloaded 3 time(s).
