flatpack
#1 Posted : Monday, February 25, 2019 2:30:56 PM(UTC)
flatpack
Was thanked: 11 time(s) in 9 post(s)
I opened (126mb) file that I need to modify which contained a ton of objects and took a very long time to put together.
Each layer says the objects are there (i.e. says the number of objects exist). But they are not visible.
I've tried quitting out of Shark, turning on and off layers, ensuring all objects are visible using Show All...
When I hit select-all, although I can't see the objects, the Inspector displays the correct number of objects (1746 total). I tried to copy-paste into a new doc and still they're not there.
The only thing that shows up are four mesh objects (which are four of the same object copied), a jpg, and a few construction lines.
Any ideas what the problem could be?
Edited by user Monday, February 25, 2019 2:40:46 PM(UTC)  | Reason: Not specified
#2 Posted : Monday, February 25, 2019 3:53:52 PM(UTC)
Was thanked: 106 time(s) in 82 post(s)
No but I feel your pain. I had this when I was experimenting with clear undo on save, and clean part and all this. Stuff just went missing, same as you it says its there but just isn't.
Not helpful but at least you know your not alone :-)
Shark CAD + Power Pack Pro
#3 Posted : Monday, February 25, 2019 3:59:31 PM(UTC)
Was thanked: 234 time(s) in 203 post(s)
I would likely need to see the actual file and bring into the debugger to look at some of the internal attributes.
Any chance I could get the file? (i.e. dropbox?)
Vice President Software Development
flatpack
#4 Posted : Monday, February 25, 2019 4:00:36 PM(UTC)
flatpack
Yup. Pain and frustration indeed. Well thanks for making me feel not alone. I just don’t know what happened. I didn’t reopen this file since it was worked on in December. Now to reconstruct everything over the next couple of days.
flatpack
#5 Posted : Monday, February 25, 2019 4:01:59 PM(UTC)
flatpack
Yeah sure I can do that — thanks. I’ll email you the Dropbox link
flatpack
#6 Posted : Monday, February 25, 2019 4:37:50 PM(UTC)
flatpack
Tim, I sent it to one of your addresses.. pls let me know if you don't get it.
