                Hi! It seems to be a simple task but I encountered problem with it: I have a USB-C model, it's composed by different parts. Anyway I made it one single group. Where can I find the measures of the group ? Width and Height for example. And it's possible to change them? I tried using the "scale" function but it only works in percentage ( similar to percentage, in reality it uses number like 1.0, 0.5 etc...) What am I doing wrong ? Thanks!
                >>Where can I find the measures of the group ? Width and Height for example.   Try Verify :Bounding Box Tim
    Tim Olson  IMSI Design/Encore
                Ok perfect. The bounding box works in order to find the general measures of the object. Thank you? One is solved. :D About the way to change size of the object using the measures? Do I need Shark? I'm using ViaCad Pro 11
                >>About the way to change size of the object using the measures?   There is not a way to scale a group via length, width measures.   However, from the transformation tools, use the scale by anchor, start reference, and end reference point.  Where your start/end reference points can indirectly define your measure. Tim
                Ok Tim, thanks, I'll try. In my opinion it's an unusual way of working. Has the superior version ( Shark )  the same logic ?
