Thanks: 320 times Was thanked: 192 time(s) in 136 post(s)
I created a Dodekaeder with lines, it is possible with shark construction tools but need much time. Now i want that the lines be a solid. I have no idea how to do that.
Dodekaeder.slt
(14kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
May be a solution:
Choose Select Deep function, press an hold Shift to select multi lines. Select Cover Surfaces and click the lines of the first pentagon. When completed the pentagon, the surface will be build.
Tested with 2 surfaces as shown in the picture.
horst.w
GER
Edited by user Thursday, April 25, 2019 3:49:07 PM(UTC)
(61kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 181 times Was thanked: 159 time(s) in 109 post(s)
As horst.w suggested, cover surface and stich solid should work.
Dodekaeder2.sfx
(64kb) downloaded 1 time(s). L. Banasky attached the following image(s):
(65kb) downloaded 2 time(s). You cannot view/download attachments. Try to login or register.
But this is to much work. I can also put a sphere in the middle and trim the sphere. But the trim solid tool is a little bit balky, therefore i can also creating infinite planes on each pentagon and split solid and delete the unwanted part. But all this procedures are very to much work. I want a tool where i can select all lines and the solid is made. Call it can be called CoverSolid or Auto-Surface.... In the gigabytes of content are also parts which be made with 3d lines. Also this parts cant be converted easily in a solid.
