shorton
#1 Posted : Saturday, May 4, 2019 10:13:25 AM(UTC)
shorton
Was thanked: 5 time(s) in 5 post(s)
Can someone explain or point me to a tutorial that shows how to remove a fillet I added previously?
#2 Posted : Saturday, May 4, 2019 10:17:13 AM(UTC)
Hello
What are you looking to remove a fillet from a 2d profile or a surface or solid ?
shorton
#3 Posted : Saturday, May 4, 2019 3:26:25 PM(UTC)
shorton
Hello
I think it's a solid. (But maybe it's the surface I want to remove, fuzzy on surfaces). See attached. I want to remove the fillet from the rim of the "bowl"
SquareBowl.vc3 (123kb) downloaded 14 time(s).
#4 Posted : Sunday, May 5, 2019 12:36:27 AM(UTC)
Was thanked: 150 time(s) in 95 post(s)
Originally Posted by: shorton Go to Quoted Post
]I think it's a solid. (But maybe it's the surface I want to remove, fuzzy on surfaces). See attached. I want to remove the fillet from the rim of the "bowl"
Hello Shorton,
This is a very easy one because your part has history...
Go to the concept Exploreur -->Entities
And remove the feature "fillet"
When there is no history, the "remove face" tool works pretty well...
Capture d’écran 2019-05-05 à 08.30.52.png (703kb) downloaded 7 time(s).
horst.w
#5 Posted : Sunday, May 5, 2019 1:29:04 AM(UTC)
horst.w
Another solution:
Select first the bend with the SELECT DEEP flash and press Delete ....
Repeat it with the fillet. Part by part.
Thats all.
Fillet deleted.png (90kb) downloaded 4 time(s).
shorton
#6 Posted : Sunday, May 5, 2019 2:32:30 PM(UTC)
shorton
Hello Shorton,
Thanks. It's the inside the bowl rim I'm wanting to delete. I tried using the explorer entities but when I did it didn't behave as I intended. I gor a 180degree fillet coming from the bottom to the top. I wanted it to just undo and leave the perpendicular edge as was there before the fillet.
That aside, can you explain how I would use "remove face" tool?
#7 Posted : Monday, May 6, 2019 4:39:14 AM(UTC)
Dear Shorton,
Choose the remove face tool (picture)
Hold on the shift key and select each surface of the fillet, all around
That's it...
JL
