shorton
#1 Posted : Friday, May 10, 2019 2:35:30 PM(UTC)
shorton
Was thanked: 5 time(s) in 5 post(s)
I can't get the dimension tools to work on solids. Say you have a trapezoidal hole in a part and you wan the angle between 2 sides. How can you dimension that? I can't even get a square hole to dimension the 90deg angle between sides.
#2 Posted : Saturday, May 11, 2019 5:09:27 AM(UTC)
Hi Shorton,
To my knowledge, it is impossible to angle dimension between surfaces...
My workaround is to draw lines on the surfaces and attach dimensions on those lines...
The same for radiuses...I draw a 3 point circle or arc to get radius or diameter...
Software improvement ?
JL
murray
#3 Posted : Sunday, May 12, 2019 6:11:38 PM(UTC)
murray
If you want to dimension a solid that isn't created from 2D figures or curves, another workaround is to copy the solid and change the copy's object type to curves, which can be dimensioned.
