flatpack
#1 Posted : Tuesday, July 16, 2019 10:35:05 AM(UTC)
flatpack
Was thanked: 11 time(s) in 9 post(s)
is there a way to save the settings to Draw View Properties?
I wish I could have Edges to be set to Precise Curves by default. Saves me time especially when there are lots of parts...
rockyroad_us
#2 Posted : Tuesday, July 16, 2019 11:41:39 AM(UTC)
rockyroad_us
Was thanked: 24 time(s) in 23 post(s)
are you on a mac or pc? Every time I open the model to sheet, mines set to the last one used. I'm on a mac. also maybe you meant the method as there's no setting for edges. I have my draw views clicked.
FX 9-1224 Pro10-1371
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
flatpack
#3 Posted : Tuesday, July 16, 2019 12:21:03 PM(UTC)
flatpack
Thanks, I'm on a Mac... its for New Draw View and when I open the Properties (attached what it looks like when i right click to open Properties). I want everything defaulted to UNchecked and the "Edges" field to default to Precise Curves.
When I make drawings, I copy one part at a time and create a new draw view, paste it into the draw view and then slide right/left/up/down etc to make the various orthographics.. One part per page. Not even sure if this is the best way to handle it in shark..
Default Properties - New Draw View.png (76kb) downloaded 10 time(s).
rockyroad_us
#4 Posted : Tuesday, July 16, 2019 12:34:02 PM(UTC)
rockyroad_us
I see now. I was on version 10. No wonder it is called Method there and not Edges. Will try V11 and see if it sticks.
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
flatpack
#5 Posted : Tuesday, July 16, 2019 12:55:01 PM(UTC)
flatpack
Hmm... I'm using SharkCad 10 myself..
rockyroad_us
#6 Posted : Tuesday, July 16, 2019 1:13:36 PM(UTC)
rockyroad_us
I see. The new draw view command doesn't stick to the last one used but it does stick when doing model to sheet. You might have to use the option command and copy drag a view. You can then change the contents of the view to which ever side you want. I personally don't use the new draw view at all. I just copy view and change it accordingly.
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
flatpack
#7 Posted : Tuesday, July 16, 2019 1:30:46 PM(UTC)
flatpack
Good idea. I'll try that instead. Thanks!
