hello,
Tim? it's possible for the next version, this fonction for the best results (technical rendering) in rendering work?
differents rendernig mode in same interface and same view? wow!:p
See please, the attach files.
Cordialy.
Antoine
(24kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
Also would it be possible to change the preset Quick Render settings? and/or add a plastic/phong setting without mirror reflection? That would be a possible solution to problems I have with OPen GL rendering with perspective. Best of all would be a phong+wireframe/toon with outline Quick render setting. Nick Robinson
hello I put this post up to date. Cordialy Antoine
Tim? are you a possible evolution for this? in the future version? Antoine
