Im using ViacadPRO Version 11 Build 1417
I have created this lines and circles, see attached.
I can't Push/Pull the object, why? The lines and circles are created in 3d mode, is this the problem?
Thanks in advance.
rk-hpd attached the following image(s):
(448kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
I too can confirm this. I had it a few days ago.
afaik the push pull tool only works if your profile is in a major workplane. you can try to set the workplane to your object (or profile). goto menu workplane -> select objects and select your profile
3 users thanked rokoko for this useful post.
thanks! after a while it worked, not from beginning, WorkPlane - Show Work Plane is helpful to set it correct.
Thanks: 5 times Was thanked: 26 time(s) in 22 post(s)
Often it helps - to Join Curves + - to Cover Surface horst.w GER
Thanks: 326 times Was thanked: 202 time(s) in 140 post(s)
Originally Posted by: horst.w Often it helps - to Join Curves + - to Cover Surface GER
No, join curve create a spline from arcs and lines, thats absolutely not good! Sometimes i use a tool from CADKas to make arcs and lines from splines automatically.
Edited by user Thursday, January 23, 2020 3:42:34 PM(UTC)
