rk-hpd
#1 Posted : Saturday, January 18, 2020 3:40:48 AM(UTC)
rk-hpd
Im using ViacadPRO Version 11 Build 1417
I have created this lines and circles, see attached.
I can't Push/Pull the object, why? The lines and circles are created in 3d mode, is this the problem?
Thanks in advance.
rk-hpd attached the following image(s):
#2 Posted : Saturday, January 18, 2020 8:50:46 AM(UTC)
I too can confirm this. I had it a few days ago.
rokoko
#3 Posted : Saturday, January 18, 2020 11:01:29 AM(UTC)
rokoko
afaik the push pull tool only works if your profile is in a major workplane. you can try to set the workplane to your object (or profile). goto menu workplane -> select objects and select your profile
thanks 3 users thanked rokoko for this useful post.
L. Banasky on 1/18/2020(UTC), rk-hpd on 1/19/2020(UTC), Saki on 11/5/2025(UTC)
rk-hpd
#4 Posted : Sunday, January 19, 2020 7:13:27 AM(UTC)
rk-hpd
thanks! after a while it worked, not from beginning, WorkPlane - Show Work Plane is helpful to set it correct.
horst.w
#5 Posted : Sunday, January 19, 2020 10:12:35 AM(UTC)
horst.w
Often it helps
- to Join Curves +
- to Cover Surface
horst.w
GER
#6 Posted : Tuesday, January 21, 2020 6:00:11 AM(UTC)
Originally Posted by: horst.w Go to Quoted Post
Often it helps
- to Join Curves +
- to Cover Surface
GER
No, join curve create a spline from arcs and lines, thats absolutely not good! Sometimes i use a tool from CADKas to make arcs and lines from splines automatically.
Edited by user Thursday, January 23, 2020 3:42:34 PM(UTC)  | Reason: Not specified
