Edzard
#1 Posted : Tuesday, April 28, 2020 1:57:23 AM(UTC)
Edzard
I've got an issues with the slab primitive from the tools palette (not the architecture tool).
In a first stepp I create a slab by clicking four node on the workplane.
In a second step I edit the four nodes in the Inspector form to bring it to "more exact" dimensions.
After clicking "Apply" the slab appears distorted in that way that there seems to be a fifth node that sticks at the origin of the slab. Is that an internal node that was generated when the contour of the slab was closed?
However, how can I edit a slab?
I hope the attached pics explain what I am writing about.
Edzard attached the following image(s):
cad'n'stuff
#2 Posted : Tuesday, April 28, 2020 1:47:56 PM(UTC)
cad'n'stuff
Was thanked: 41 time(s) in 21 post(s)
I just tried it and this bug seems to be in V10 as well. I guess there's nothing you can do about it, exept from forwarding this bug to the developer.
The alternatives for slab:
- If your slab is rectangular, just use the "block primitive" instead
- Other shapes can be done by drawing and extruding an "n-sided polygon".
thanks 1 user thanked cad'n'stuff for this useful post.
Edzard on 4/29/2020(UTC)
Edzard
#3 Posted : Wednesday, April 29, 2020 11:32:23 AM(UTC)
Edzard
Thanks to cad'n'stuff.
In the meantime I create the slab in a separate model at the origin, save it and after that I import it to the big model I am working on.
I then use functions like trim, draft face and move face to fit it into the big model.
