Import/Export
Catia V5 export revision level
                Can anyone confirm what revision of Catia V5 is actually exported using V10/V12.
                I've asked and didn't get an answer. I too work like you and sometimes the customers need V5 part for programming. I have a catia check version as when I was testing this Shark software v10 or 11 at the time I passed an exported file to someone I knew working in R21 and it gave a revision error.
                go to the Shark subdirectory "\exe" and select a file of the used CATIA library as e.g. "CATGeometricOperators.dll", right-click and select "Properties > Details" for the release date which can be compared with the
CATIA release history .
For an exact version information save an empty file, open with a
text editor  and check (around) line #24 for the version information, alternatively searching with "V5R" shoud yield a result. My SCP v10.0.0 (build 1354) does show "V5R25SP0HF0".
hth
                Originally Posted by: posh.de  go to the Shark subdirectory "\exe" and select a file of the used CATIA library as e.g. "CATGeometricOperators.dll", right-click and select "Properties > Details" for the release date which can be compared with the
hth
So release 25? If so why? I had this discussion with them and that export should be in like R14 or earlier to ensure everyone can open it?!?!
                Originally Posted by: UGMENTALCASE  So release 25? If so why? I had this discussion with them and that export should be in like R14 or earlier to ensure everyone can open it?!?!
because the recent translator revisions regularly do contain all the latest bug fixes and improvements (as w/ every data ecchange format) nobody wants to decline. Having the choice to select the CATIA version to export too would be the right way.
                Originally Posted by: posh.de  Originally Posted by: UGMENTALCASE  So release 25? If so why? I had this discussion with them and that export should be in like R14 or earlier to ensure everyone can open it?!?!
This is true. So if customer don't have r25 import then it's v4 all the way. Same thing essentially.
                In fact, thinking about it. If they have had these translators for years on end they probably could implement a version selection tool to it
                Originally Posted by: UGMENTALCASE  If they have had these translators for years on end they probably could implement a version selection tool to it
depends, if the used CATIA license does cover ine resp. the latest version only...
Import/Export
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
