Dav01
#1 Posted : Tuesday, May 19, 2020 8:27:34 AM(UTC)
Dav01
Can anyone confirm what revision of Catia V5 is actually exported using V10/V12.
There is no granularity when selecting V5 as an export (which would be fantastic), unlike many of the other export options, and so you are at mercy of the system.
I work with a number of clients and they use Catia V5 revisions from 18 up to 24 - No one I deal with actually uses the latest revision as it takes so long for these to be validated by their large IT teams.
My actual issue is that version 8 FX of Sharkcad crashes when I try to export these parts (simple step format bolts) and I cannot open them in Catia V5 Revision 24 as they are a further revision along when I use V10.
I currently don't have access to the step translator in Catia, that is an optional extra in Catia, and incidentally costs far more than a full Sharkcad pro licence and I do appreciate the number of import/export options which is the main reason I have Sharkcad in the first place. I'd rather stay here than move over to a pure viewer such as 3D-Tool as sometimes its convenient to modify the data.
#2 Posted : Tuesday, May 19, 2020 9:13:52 AM(UTC)
Was thanked: 303 time(s) in 205 post(s)
I've asked and didn't get an answer. I too work like you and sometimes the customers need V5 part for programming. I have a catia check version as when I was testing this Shark software v10 or 11 at the time I passed an exported file to someone I knew working in R21 and it gave a revision error.
I passed this on probably about 12 months ago and heard nothing.
Hopefully someone might know?
GARLIC on 5/19/2020(UTC)
posh.de
#3 Posted : Wednesday, May 20, 2020 5:53:12 AM(UTC)
posh.de
Was thanked: 49 time(s) in 36 post(s)
go to the Shark subdirectory "\exe" and select a file of the used CATIA library as e.g. "CATGeometricOperators.dll", right-click and select "Properties > Details" for the release date which can be compared with the CATIA release history.
For an exact version information save an empty file, open with a text editor and check (around) line #24 for the version information, alternatively searching with "V5R" shoud yield a result. My SCP v10.0.0 (build 1354) does show "V5R25SP0HF0".
hth
POSH GmbH
www.posh.de
#4 Posted : Wednesday, May 20, 2020 6:22:14 AM(UTC)
hth
So release 25? If so why? I had this discussion with them and that export should be in like R14 or earlier to ensure everyone can open it?!?!
posh.de
#5 Posted : Wednesday, May 20, 2020 6:34:11 AM(UTC)
posh.de
because the recent translator revisions regularly do contain all the latest bug fixes and improvements (as w/ every data ecchange format) nobody wants to decline. Having the choice to select the CATIA version to export too would be the right way.
POSH GmbH
www.posh.de
#6 Posted : Wednesday, May 20, 2020 6:36:21 AM(UTC)
This is true. So if customer don't have r25 import then it's v4 all the way. Same thing essentially.
#7 Posted : Wednesday, May 20, 2020 6:46:20 AM(UTC)
In fact, thinking about it. If they have had these translators for years on end they probably could implement a version selection tool to it
GARLIC on 5/20/2020(UTC)
posh.de
#8 Posted : Wednesday, May 20, 2020 7:02:55 AM(UTC)
posh.de
depends, if the used CATIA license does cover ine resp. the latest version only...
POSH GmbH
www.posh.de
