Ocean
#1 Posted : Thursday, May 21, 2020 3:51:28 PM(UTC)
Ocean
Hi all, I've been having this issue with via cad 2d/3d, whenever I start the application it seems that the settings I have changed in preferences previously are all reverted to factory. For example I change units from inches to metric in one session, then quit the application and re open it, and all settings would have been reverted to defaults.
Right now I am not really sure what else I can do.
via cad 12
Win 10
#2 Posted : Saturday, May 23, 2020 1:35:18 PM(UTC)
Maybe it help when you run the Application as administrator. Punchcad use the config folders in windows: C:\Users\%username%\AppData\Local\Punch!\
This frolder should be protected and if it protected is something wrong with your setup.
Edited by user Saturday, May 23, 2020 1:35:50 PM(UTC)  | Reason: Not specified
