V12 Pressure Deform Not Working
Thanks: 4 times Was thanked: 7 time(s) in 5 post(s)
Simple test with V9 Pro and V12 Pro side by side with the same type of solid model. That flat side of a simple cylinder. Pressure deform works on V9, but not V12. To be brutally honest the ONLY reason I upgraded to V12 was because a customer had a newer version and I was not able to open his dead simple files in V9. There was not one damned thing in his models that necessitated they be incompatible. Its more than a little annoying to have to upgrade just to read a file and then lose features.
1 user thanked Bob La Londe for this useful post.
Quote: V:VCP Version: 12.0.0 Build: 1536 Language: You are running the most current build. No update is necessary.
Before somebody asks. No Point Deform and Curve Deform do not work either.
