boydage
#1 Posted : Monday, February 8, 2021 7:48:43 PM(UTC)
boydage
I find SharkCad often locks up. If I dont save my work every 10min I lose it all. Quite an unstable program really. Does anyone know how to set an auto save or auto backup?
Also I have no idea what this is talking about when it asks to resolve links. Can someone please tell me what links are in solid modelling? And then how to resolve them?
I guess knowing this information will be to advantage. But I get this error message when I try to save sometimes.
Thanks in advance
bbuxton
#2 Posted : Monday, February 8, 2021 10:46:18 PM(UTC)
bbuxton
Japan
Was thanked: 29 time(s) in 14 post(s)
The "resolve links" is for associativity.
So if you create a spline and extrude it is still linked to the spline. If you later change the spline the extrusion should update.
Some operations will break this and others may need you to update the link between the spline and extrusion - resolve link.
This is perhaps one of SharkCad's most important features but it does come with a performance cost.
MaiFy
#3 Posted : Tuesday, February 9, 2021 10:05:47 PM(UTC)
MaiFy
Hi Boydage.
Different versions have different features, but this is how I set mine.
boydage
#4 Posted : Friday, June 10, 2022 10:18:33 PM(UTC)
boydage
Thanks for that reply.
boydage
#5 Posted : Saturday, June 11, 2022 2:32:26 AM(UTC)
boydage
I do have another question though about modelling. I find that when I am designing an assembly. That at times I will use the "align" tool to, well, align components inside the design.
But that, creates issues later if I want to move the component I aligned in the past. Often it wont move properly with the gripper. Often it (the previously aligned component) is unpredictable. Is there a way to use one of these commands only once and not have it stick? Know what I mean?
I find, with Shark, that I am always realigning things. The only way I can keep my drawing safe from corruption is to "lock" parts.
boydage
#6 Posted : Saturday, June 11, 2022 2:34:57 AM(UTC)
boydage
Another question, say I create 20 or so spline points in a line. This to drill a series of holes at proper spacing. Is there a way to select all of these points in one hit to drill multiple holes? Currently its several steps per hole.
#7 Posted : Saturday, June 11, 2022 6:54:51 AM(UTC)
Was thanked: 180 time(s) in 127 post(s)
The Assembling Tools works only when he History woll be deleted. Select all and remove Links or Clear the history woth File> Compact
The Pattern Feature with the Option "Copy to Locations" make this a little bit faster, but you have to select every point, and sometimes it works not and i dont know why.
Please open new threads for your questions in future. Talking about this in such a old thread is not the right way.
Edited by user Saturday, June 11, 2022 6:55:51 AM(UTC)  | Reason: Not specified
